We have a small problem, and we saw on the forum that you have a lot of experience with this type of bike!
We recently cleaned the carbs after winter storage. Now we do not really know where to connect all the fuel lines. There are 3 tubes comming from the tank. 2 are going to the carbs and 1 is an overflow. Now we still have 2 tubes comming from the carbs going ??????????? and this is where it goes wrong we don't have a clue where these 2 tubes have to go. The bike is still running nicely! Help us please!!!!
patrick
carb solution
ok big guy the 2hose comming out from the top of the carburators are overfloo tubes, and the 2hose comming from bottom of the carburator is for fule going in to the carbs. if the petcock is presure operated then you have one more hose coming from between carburator and engine connecting to the petcock. depanding on the bike the top 2hose coing from carbs on 93gsxr750 goes to the top of the airfilter housing.
hope all this might helps. :wink:
carb solution
