1 - 1 of 1 Posts
I have a 2008 GSX 650 F. She sat for three years and got rusty tank did not realize till after 100 km ride when coming home throttle response was not there open the tank one got home to find rust inside the tank disassembled change the fuel pump and filter had the injectors serviced put it all back together went for a ride 10 minutes OK and then she would not go past 7000 RPM I pulled over shut the bike off started it back up ran no problem for 10 minutes And the odour of gasoline was whenever I stopped it’s not dripping out but there is some fuel air vapour escaping. there also were two rubber washers that were left in my tray after putting it back together the diagram says they’re just washers for the injector rail on the bolt side
Please help
1 - 1 of 1 Posts
