Hi all, yeah i know it's a lot, hang with me!.......
It's a '95 Kat 750...600 block bored out, everything else on bike is for a 600, anyways.....Air filter is good and plugs are OK, carbs have been rejetted and it has yoshimura headers and can.
Couple days ago bike started runnin like crap...rough idle and had a noticeable sputter or miss that increased in frequency with the rpms....then SEEMED to smooth out at 4 or 5k rpm, also the bike is not smoking. I suspected bad gas, I had filled up earlier that day, so I drained it and put fresh fuel in with no change. One thing to note, after starting and allowing to idle, the 1,2, and 4 headers got HOT quick, while I could still almost touch 3 for a split second.
I ran it for a bit with the tank off, then quickly pulled the plugs. Plugs 1, 2, and 4 had raw fuel on them. 1 and 4 share a coil, and 2 and 3 share another. I looked in on the coils where the wire connects, wire looked nearly rusty, as was the needle that stabs the wire on each of the misfiring plugs. #3 looked good.
I cut the wires back for a fresh connection, and scraped the needles as best I could, no change.
The oil level has not changed, battery is 100%, and fuel lines are not plugged. The unknowns are if it's the carbs, or the ignition. Up until this, the plugs have been very consistent in thier wear and condition, and this was not progressive, showed up one evening.
I'm running up to WallyWorld for a cheap spark tester thingy to see if the ignition is OK, it's only a couple bucks, might as well try.
I tried to be as thorough as possible, but I've run out of ideas!
Also I would think that the misfiring cylinders would be cooler?
Thanks for any ideas....
Dennis
Dennis
