On my 98 Marauder 800, I have to remove the bolt on the rear of the take, unbolt the fuel cock(should be one screw), then slide the tank straight back and lift. There isn't far to go with the fuel lines attached, but you should be able to get it out of the way enough to do most regular maint. Hope this helps.
