I have a Suzuki gs450 engine, i dont know the year or model but the number on the motor is GS450-130177. Can anyone tell me the details about that number? What it all comes down to is findind an accurate wiring diagram for it. Thanks to anyone that can help.
try pdftown.com managed to get gs850 1's from there and the number is the import / export number or depending where it was on bike could be the seriel number from manufacture anlo look on forums at how the bikes changed over years that may help you pin point the year bacause every 2 years or so suzuki made little changes
The number is located on the side of the motor. I actually figured out how to wire it since my first post, the motor turns over and gets fuel, but no spark. I dont know what i should do now...
wiring problems
I am not sure if you are stilling having issues with the spark on your ride but i had the smae problem and i started at the ignition (where you put the key in) you can actually take that apart and start searching which wires are hot. I also know you must have battery power to create and sustain spark. i dont know if this helps.
