Hi I have a 1999 gsx 600f and the regulator as gone and I don't know where it is any help would be great
Thanks dave
Thanks dave
Gone as in missing ?
Or gone as in "has stopped working" ?
Are you really saying that you don't know where on the bike the regulator is located ??
I don't understand the question.
Some of the GSXRs had them mounted under the belly pan yours may well be fitted there too...cant see them changing the harness too much between similar models. Also there were some Suzuki models that had a problem with this sort of thing due to them dumping excess voltage through the reg/rec and causing them to overheat.
A Honda reg/rec fits some models but I am unsure which ones. Also Later models had the reg/rec mounted in a different position in the air flow to allow cooling
I replaced the Suzuki regulator with the Honda regulator, easy swap, also replaced the stator coil assembly and re-routed the headlight circuit away from the stator circuit - charges better.
