hey guys i was wondering if i could get some help.. i have 2002 gsxr 750, the other day i took her for a nice easy ride, (didnt even leave my neighborhood), i pulled into my driveway and my tranny wouldnt go into neutral, infact it was stuck in 1st and the shifter seemed "locked" in place. after a couple rocks back and forth and a couple up and down kicks on the shifter it finally popped into neutral, so just to make sure it didnt happen again i took it back out and it seemed to go through the gears ok.. a little rough to shift but it was still shifting.. any ideas on whats causing that? thanks for the help :bluethum:
Oil change may be due... can make a big difference...cable clutch adjust to 3mm play at lever ...Hydraulic bleed at slave cylinder.
