1 - 7 of 7 Posts
I just got my bike back from the shop after its first service. Now it will occasionally begin to lope and stutter while warm idling. I haven't been able to isolate and replicate the conditions to cause the loping, but I was wondering if I should bump the idle up. The tach currently reads 1K at warm idle.
Sorry 'bout that:
2004 Suzuki GSX-R600; 700 miles. Just had it serviced and 'tuned'. Not real happy with the results of the 'tuning'.
Discussion Starter · #6 ·
Will do, thanks.
Also: I am able to successfully recreate the loping condition when engine is op temp range (180-195F) by slightly bumping the throttle (200-500 RPM) and quickly releasing it. The engine will then sound like a V-Twin and lose RPM.
Doesn't the manual say something about keeping the idle at 12-1400 RPM? I had a little problem with stalling, not just because of the light flywheel, but because my idle was just barely hovering over 1k. After I adjusted to 1200 RPM, problem(s) went away.
1 - 7 of 7 Posts
