I have just bought a used 2009 S40 Blvd. Apoologies in advance for the "newbie question"
it runs great - just over 10k miles - but as I am getting used to it I have noticed that the handlebars are slighly off-center (pointing a little to the left) when the front wheel is completely straight
Might this be a serious issue? I know with my bicycle I would just straigthen the bars and re-tighten the center nut - is there a similar method on the Blvd.?
The bike was dropped once by previous/first owner - slight impact from the right side - I am thinking this may have been the cause?
(of course I didnt notice it when I was test riding before purchase)
Yes it is likely that the front forks are just slightly out of alignment.
Unless your front tire is wearing funny, it is not a real problem.
Hopefully someone here is familiar with that model and can help.
If not, a Zuki dealer or independent shop probably can probably straighten it out in under 5 minutes.
Or just don't worry about it until it's in the shop for something else.
Fully agree with ER...you can loosen the top and bottom triple tree pinch bolts slightly where the fork legs go through and bounce the front end up and down a few times....this generally pulls the forks parallel. Dont forget to tighten the pinch bolts back up to torque.
