Both headlights on my 2000 GSXR600 just stopped working. Everything else (turnsigs, brake, tail light) is working fine. I didn't have a twelve volt power supply to test the lamps but they look ok, no broken filaments or anything. Besides, both light stopped working at the same time. I check wiring harness for loose wiring connectors and wire but I can't find anything obvious.
Can anyone Help?!! Am i missing something? Please Advise,
My email address is [email protected]
Thanbk You,
Christopher
· Super Moderator
It migt be a pinch wire... Ive had that problem multiple times
Welcome to the forum.
You get the "zombie" award of the month.......for bringing back to life a thead that has been dead for 7 YEARS !!
:mrgreen:
Since you did, the most common cause of headlight failure is the switch contacts in the start button that cut off the light while starting.
