1 - 12 of 12 Posts
Anyone know of helmet speakers that don't leave you with 24-36" of wire hanging from your helmet when not in use?
Dastardly villain
I have found it pretty easy to route the wire back on itself in the cracks of the padding to resolve this issue. But I usually have used regular headphones and mocked them into the helmet instead of buying specialized helmet headphones.
If you were a little bit closer to me, I could fix that for you in about 10 minutes....or less......with a soldering iron and some shrink sleeving. If the case comes off the plug, even easier.
A caution if you get a cord shortened: Figure the absolete most slack you will need and then leave a little bit more; it is hard to anticipate ALL the situations.
Helmet Speakers with Short Disconnect
__________________
I just bought a set of sound isolating earphones (Shure SE115) from Best Buy. They are about 20 in. at the disc. point. They sound great, and are $100.00 a bit much. I have not used them on a ride yet. They don't stop all outside noise. It's like having earplugs in that play music.
Check out IMC Motorcom. The speaker cables get mounted under the helmet padding and the disconnect (on mine) is right at the edge of the shell.
Discussion Starter #8
perfect! thanks. I thought I'd seen this before but was coming up dry on google search.
How do you like them? Would you purchase again? I'll occasionally use it for tunes and maybe gps.
I would buy them again for sure. You're not going to get Dolby Digital sound out of them or anything and the volume is totally dependent on how much wattage your ipod/gps/whatever is pushing. They do work quite nicely though.
LG makes a blue tooth headset that is virtually wireless and hangs around your neck and has controls on it there is also a clone on Ebay for less I paid about 45 on Amazon Love it
1 - 12 of 12 Posts
