I have a '99 Katana 600. I am searching for a good set of forks and a front wheel. I bought a set from a '96 but the caliper mount on the forks were different :x so I took them back. How can I find out for sure what other years/models have forks/tripple clamps/rims that will fit???? Help!
Discussion Starter · #2 ·
Ok, well it seems each year or model is probably going to be different....sooo....what if I get the forks with triple tree, brake calipers with lever and line, and the front rim with rotors off say an '01 Kanata 750? Would that work out? I mean will the tree fit my yoke? If so it seems everything else would have to work....help.
Go to bikebandit.com and you can reference each year and make to check for common parts. 89 to 97 is the same and 98 and newer is also identical. I do believe Kat 600 and 750 used the same stuff. Good Luck , Ed.
