Just got an R6. Having problems with turn signals. It has been butchered. Turn signals only work when bike is runnings. Somebody put Led . Turn signals on it and cut wires. Only burn dam unless you start the bike. If I turn on the headlights on high beam the turn signals stop working. Put headlights on low beam and they Flash a 100 miles an hour. And I lose. a head lightI am not electrician that's for sure. The wiring on the bike is a nightmare can anybody help me?
Turn signals only working when the bike is running is NOT a problem.......necessarily.
IF.....the "turn signal" bulbs also glow all the time as "front marker lights", then they are supposed to go off with the high beams.
It sounds to me like the fast flashing is the only real problem that you have.......and the easy way to solve that is to put stock bulbs back in the sockets, if the stock sockets are still there.
If the stock bulb sockets are NOT still there, then do a "google" search on something like "signals flash too fast".
The fix for that on a motorcycle is almost identical to any other vehicle.
