I have both an AC-11 and Cl-14 . Does anyone know how to pull out the "REMOVABLE LINERS" all i can get out are the cheeks pads.The rest of it looks TAPED to the stryofoam.
Sorry,
Only the cheekpads come out.... Only the HJC AC-10, SyMax, AC-X1, CL-X3 models have removable interiors.
Should you want to clean the inside of the helmet you can do one of two things... The easiest is buying Frabreeze and spray it sparingly inside to get rid of the smell. Or the second, which will take a little work is to use a solution of baking soda and water to clean the liner. After cleaning the helmet interior, rinse with a damp cloth and allow to air dry at room temperature. High heat and strong solvents will damage the liner.
katana04 said:
Sorry,
The AC-11 has a removable liner http://www.hjchelmets.com/ac11_solid.htm
Shell: Ultra light weight advanced composite weave fiberglass, Dyneema®, Kevlar® shell.
Ventilation: ACS ventilation system featuring raised air flow channels combined with 7 vents.
Interior: Removable, washable DuPont CoolMax® interior and cheek pads for maximum perspiration absorption.
Others: 2 stage pivot shield system for maximum seal.
Size: XS to 2XL.
