I?ve changed the headlamp on my Honda motorbike from factory one into classic shaped and now engine and oil light are coming up all the time.. + now tachometer is showing revs from right to left :/
Any clue what might go wrong??
Does this needs to be resent by Honda to get t working??
Cheers!
Well the obvious answer is that you did something wrong; wiring mistake or wrong type of bulb in the new light.
But the obvious answer isn't always right. ;)
The NC 700 is a fairly new model and if it is a CAN bus design, you have to be really careful about electrical changes.
I don't know if it is CAN bus or not.
Have you removed (disconnected) the new headlight to see if that makes any difference ??
