So first bike and its a project bike, i rebuilt the carbs already cleaned them out and put in a new kit. What is this line and were should it go? I left it free to just try out the engine, but as soon as it cranks gas starts pouring out this line like its being pumped out not a steady drip. Its a 05 honda shadow spirit.
What is the OTHER end of the hose connected to ?
Sounds to me like you have some of the hoses switched.
The other end is connected to the top of the carbs to a t the diagram shows that its the carb vent hose. So i just disconnected the t and found out its the left carb that is spewing fuel. I have replaced the needle and seat but i did not think to test the float...soooo guess i am about to pull it off again and see if its the float but at least i got it down to which carb is the problem...
lol found my issue i had a missing washer under the needle and seat in one carb ooooppps running good
