there is a cover on the right side below the fake oil tank that needs to be removed. From there you need to rotate the bottom ring that has the ramps on it to increase the spring preload. If you don't have the Suzuki shock tool use a big pair of channel locks. Unload the rear suspension if you want to make the task easier.
