Front cyl 2000 1500 Suzuki cold replaced stated sig pickup cdi box battery starter cyl plugs got it to run on two cylinders but rough and only for a few minutes help me please.
Drain the gas and put in some fresh......with a dose of Berrymans B12 Chemtool.
Your fuel system or carbs might be gummed up.
B12 in the gas and then run a few times over a couple of days might fix you right up.
I've been dealing with this issue on my 98 1500 when I first bought it (2 days ago) there was a pretty serious afterfire issue. Bike will idle for a little while and just the front cylinder and idles fine on the rear but it makes me suspect timing based on its behavior.
No HIGHLY unlikely that there is anything wrong with the timing.
And if you go off chasing the ignition timing circuits and mechanisms, it likely will be a total waste of time.
Much more likely that you have an ignition or fuel issue.
I would change the plugs, check the wires and boots and put some B12 in the gas first.
Is there a stock air filter and stock pipes in place ??
Thanks for the reply (I didn't see the email come in for it) the previous owner threw a high flow k&n and a set of aftermarket pipes on it. So far looks like the exhaust gaskets were reused so I have them ordered, took the carb apart and noticed one of the choke plungers was damaged, and cleaned out jets. Tested out both coils one got damaged so that's being replaced.
See and here I've already got the thing almost completely tore apart haha but the block is still mounted which is a plus. One would think good old suzuki would have let you check the timing without having to remove the entire block haha will double check the jets, plugs were replaced as well btw. And not that I believe him really but prior owner said it was filled with ethanol free about a month before I bought it. 👍 appreciate you Easy!
No comment in particular just struck me as running really lean on the front cylinder. I thought I'd post the afterfire so you can see what I'm saw a few days ago. Maybe notice something I hadn't 🤷♂️
Related Threads
Motorcycle Forum
714K posts
59.1K members
Since 2000
MotorcycleForums.net is the leading motorcycle forum for news, specs, reviews and discussions, including road and sport, classic and dirt bikes.
