1982 Suzuki GS550L
New rider. Bought an 82 GS550L for less than a grand and it's my daily driver. Got a new rear tire after I bought it. Just replaced the spark plugs in early August and need to do the wires next. I want to get this bike up to the running condition that it should be running at. It bogs down if I go over 70mph, mainly when I get on the interstate. It'll hit about 75mph then bog down to about 43mph then I am able to get it back up to 60 and then I get off at the next exit. I have to shift at 6,000 rpm's because it wont go any higher even though it'll rev to 11,000 in neutral. I have some mechanical knowledge but it's four wheel mechanics not two wheel mechanics. I am still learning. Any help would greatly be appreciated.
As of today 9/3/21 I've dropped the bike a few times partly stupidity/ partly weather. Never hurt though thank God. But the last time was on the 9/1 in the rain. I was making a right hand 90 degree turn and there was pea gravel and yep the rear tire lost traction and spun 180 degrees clockwise and down I went. I got her home then covered her up. Yesterday I rewrapped the exhaust pipes and remounted my bags. I noticed there was no oil in the gauge on the side so i put what i had in it and saw that i had half. Today went to go to work and had to call off because the bike won't go over 10mph. I need to figure this out and i Can't find any manuals online for the assistance. Right now it's acting like it's running out of gas but when I open the tank I can see that i have a few inches of fuel left even though my gauge is reading empty. The gauge has issues with working when it wants to also.
Welcome. You likely aren't going to like my answer:
You have a bike that is almost 40 years old.
Finding and fixing all the things that might be wrong with it will likely cost you MORE than buying a different bike that is half that age. Really.
Some of your comments makes it sound like it has been heavily modified......like straight pipes maybe and a different intake too probably. Those things alone can cause it to run bad.
First, make sure that it has enough gas in the tank.
Then give it a healthy dose of Berrymans B12 Chem tool in the gas.
I would NOT recommend that you spend (waste) any more money than that on it.
