I have a 1995 suzuki intruder 800 and when I go down my road a hit small bumps it stalls and starts back up it only happens when I hit bumps what should I do to get it to quit?
Find the loose connection and fix it.
Start at the battery, then the ignition switch.
Tapping on things with a small rubber hammer might help locate the problem.
When I got my '09 M50 it would occasionally go dead for no apparent reason. I finally figured out the nut on one of the battery terminals was cross-threaded. A screw goes through a hole in a box-shaped lug on top of the battery and into a square nut that's inside that 'box.' It felt tight, but it was not clamping the connection together tightly. You may have the same type of connection, and it may have the same problem.
