bolt on turbo for a bike?........ ..... .. . . . . .....
not likely
My brother put this kit on his 2006 GSX1000R. The kit was basically a bolt on kit and then he took it to a professional (someone that was familiar with turbos) to have it dyno tuned. It had a high volume/high pressure fuel pump with the regulator turned up, but still ran out of fuel about 11,500. He had it stretched out 6", lowered, MPS air shifter, and power commander. Bike would run 6.20's @ 124 mph in 1/8th mile...which would be about 9.20 @ 160 mph 1/4 mile. Stock with power commander and Yoshi pipe it made 151 rwhp. With the turbo it made 243 hp @ 7 psi boost.
Once he stepped up to the Stage 2 turbo with piggyback injectors, completely rebuilt engine with lower compression pistons and H-beam rods, straight-cut tranny gears, 10-12 inch swingarm, and 2-stage clutch the bike made 424 rwhp @ 29 psi boost. Then it would run 5.0's in 1/8th @ 140 mph....on a M/T street tire w/ no wheelie bar.
