98 750 K sat for three years. idels fine, runs fine but when coming to a stop it "loads up" and stalls takes a few min to restart
Ran fine before sitting. Hate to start changing parts ie shadetree.
Seems to be a carb issue
In Cincinnati Ohio
Drain the carb bowls.
Put a healthy dose of Berryman's B12 in the gas. (Not more than 2X the recommendation.)
Run it a bit.
Drain the bowls again.
Check the idle speed setting. The screw might be backed off too far.
What he said ^ and check filter and fuel valve, fuel lines, for deterioration thus cause crud in the carbs, and fuel tank venting....easy to do when it stalls pop the cap...a sudden inrush of air points to a blocked venting system.
