Hi,
iv sucsessfuly removed all 8 bolts and the headers on my katana,
iv bought new bolts and gaskets ready for when I put her back together again,
but for the life of me it looks like the headers don’t have gaskets on when I removed them,
and the new bolts seem a little tight ,
have I got the wrong replacement kit?
Or am I missing something?
help and advice greatly appreciated
cheers
jay
Not sure if you bought a single kit with new bolts & gaskets or if you bought bolts/gaskets seperately. You can compare the new bolts to the old ones, measure with calipers, you can sometimes even "mesh" the threads from old 'n new to see if the threads match like puzzle pieces which would indicate the same thread-pitch.
Since you found no gaskets on the headers themselves, you might look more closely at the exhaust ports as it's not uncommon for carbon build-up to cover and kinda hide the old gaskets where they're seated in the exhaust ports.
WHS^... plus check the old nuts on a random bolt then see if the new nuts will fit....they should be metric....from memory of most Jap bikes around 6 or 8mm. The pitch may be different in which case do not try and force them or you will stuff up the studs...far better to obtain the correct ones. Finally the threads may have carbon build up or corrosion a wire brush and a bit of WD40 may work wonders.
