1 - 19 of 19 Posts
· Happy-ass Lunatic
If you're in a major city, go for the Kevlar . . . it's bullet-proof.
Seriously, unless you're racing, or just have to replace them due to age and want to buy something nicer, I'd stick with the stock ones. If you're going for looks, do what you think looks best.
On the Gixer some people find the standard brake lines too spongy(especially when worked hard),changing to stainless lines is quite a popular mod.
Good brake fluid that isn't degraded is a good idea too.
Stock brake lines usually need to be replaced about every 10 years because the tough rubber eventually expands more than usual and so you need to use more brake fluid to compensate the greater expansion of the stock brake lines. The stainless steel brake lines don't have that problem and yes it's true that Kevlar is bullet proof and lighter than the stainless steel version which is good for WSBK / MotoGP bikes as they need to shed any possible weight from the bike, but who knows how good they are after 10 years or so ?
In bleeding brakes you usually start with the left side first because of the distance from the master cylinder to the caliper, so if you start with right side first you may inadvertantly force some air bubbles over to the left side.
After finished bleeding both brakes tie wrap the brake lever back and leave it over night to make sure that any air bubbles escape via the master cylinder.
· Banned
Discussion Starter · #9 · (Edited)
oooo thanks i was wondering about that since there 2 break lines for the front one. Even braid steel should be replaced alot of poeple have that missconception about them since you cant see the rubber thats under the braid it happens alot in cars for fule, and break lines they break to just like rubber but you cant see it
1 - 19 of 19 Posts
