1 - 1 of 1 Posts
I let my bike (2005 Susiki Bandit 1200s) sit for a few years and I would not run, So i ordered a carb rebuild kit and installed it, put the gas to it and every carb is leaking fuel. I believe its the o-ring that seals the bowl and carb...is there different sizes. It doesn't look big enough to seal. this kit had float and needle valve, diaphram and o-ring gasket...So i will be out in the garage removing the carbs...
Please advise......
Craig
1 - 1 of 1 Posts
