1 - 10 of 10 Posts
badkitty said:
Is this due to colder weather? It was about 85degrees 2 days ago then we got clouds and now its 60.
My bike, an '84 poorly maintained before I got it, does about the same thing. When cold like this morning, I have to put the choke on full. It starts for about 5 seconds and then slowly slows down and dies. Have do this a few times, then I must turn off the choke, turn the Idle screw to the highest and then it starts just fine. I HAVE to let warm up a good 5-10 minutes otherwise I stall at the first stop signs when pulling the clutch in.
87gsxrnut said:
Sounds like you need to pull the carbs off and clean them.
- Nut
Who me?
The carbs were clean thoroughly in June. I think they spent 4 days in the parts-cleaner-tub.
They might be not fully synced (don't know if it would cause such a behavior) and I know it needs a major valve adjustment (been told I COULD do it myself but I'm hesitating a lot).
I doubt very much the behavior of the choke though.
I have a snowblower that old. It needed its carb cleaned.
:oops:
1 - 10 of 10 Posts
