HELP. Checked stator ok. Reg ok all fuses ok coils ok cleaned all connections.
Even asked google she don't know either.
2000 road star ecu icm melting any suggestions are apprechiated.
Original melted replaced with dynatec 3000 it melted.
Stator checks good rectifier regulator battery all check good. Will syart right up with good ecu after a few minutes melts.
Trying to fond someone who had same problem and knows why it happend or how they fixed it.
Or any ideas.miss riding😞
Bad coil. Coils may statically test good, but under use one is probably shorting to ground and allowing excessive current flow thru ecu. Had this happen before on several bikes.
