Hi, I have a XV500 which I have recently purchased, its a 1982 and has been stood for many years, when I took off the float bowls it was half full of black crud,after a good clean out I had it running a bit rough, upon restarting it would then only tick over, the slightest throttle would kill it, so Ive had the carbs off 3 times and given them a good clean ie strip, jets out ,carb cleaner etc, I still have the same problem of dying when given throttle, having read many forums I now think that a passage or 2 may be blocked (pilot side of carb) the pilot jet and pilot air jet and everything or squeaky clean but I cant tell if the passages are clear, any suggestions as how to clear these
