I have a 2000 VZ800 Marauder that is mis-firing on the front cylinder only. I switched the coils and the front cylinder still has an irradic mis-fire. Test light hooked to the spark plug wire shows it is only firing about 50% or less of the time vs. the other cylinder. I suspect it is the CDI box or a short in the wiring from it. How can I check the CDI to determine if it is the culprit? Any other suggestions that may cause this firing problem would be appreciated. Thanks, Stan.
