G
Guest
·i know you can add as much accessories to help your engine out, but can you modify the actual engine block itself, like bore it out, or change the valves etc. what else it there?
//Why would you want to?soad said:i know you can add as much accessories to help your engine out, but can you modify the actual engine block itself, like bore it out, or change the valves etc. what else it there?
//With cutting edge sportbikes it's hard to improve on stock....soad said:i wanted more info about say... lighter engine block, titanium pistons, aluminum valves etc. i know more about cars and i was wondering on how much car stuff is transfered to bikes. like switching roller cams to flat head cams. or lighter engine parts.
