Hello MCF
I've recently purchased a used 2008 S83 Boulevard from a former friend and coworker who passed back in the fall of 2019. I don't know much at all about the suzuki or any motorcycle for that matter, but I do know that the gas in the tank was probably bad and that the carbs where probably affected as well. I purchased a new battery for the bike and was able to start it up....barely. I added a carb cleaner product to the gas and let it idle for a while. In the beginning it wanted to die if I opened up the throttle any. Eventually it started to rev up slightly but backfired a lot. After burning most of the old gas in the gas, I added a gallon of high octane gas and a can of seaform on the advice of a friend. He suggest a pattern of starting up the bike for 15 minutes and off for 15 minutes until the gallon was consumed. This seemed to help a little bit but I still had a lot of backfiring going on. One thing too about the backfires, they seem to being coming from only the right side muffler (pipe).
I was able to drive the suzuki to a local mechanic who said he would not be able to help me any due to the bike being too new, (he's a vintage guy). He did tell me to try to find a pair of OEM used or new pipes for the bike. Do you guys believe that the pipes will help with the backfires? He said the bike was running lean and the aftermarket pipes where one of the reasons for the sluggish performance and backfires.
When I drove the bike over to his shop, it ran poorly at low RPMs...but seemed to want to take off as the fuel burned better...I may not be describing exactly how it was handling but the bike seems to want to run and feels pretty good at times. I'm wondering if this bike is worth fixing up or should I bow out and sell it now before putting more money into it.
What do you folks think?
SteveInIndiana
SteveInIndiana
