1999 vstar 1100
parked my bike in downtown next day i get to it all the ignition had a drill bit in it and wires cut and all four were twisted together now
neutral light only comes on with kickstand up
cranks but does not fire up
has a new battery
i fixed the ignition it works
replaced diode
replaced starter relay
checked every fuse
grounded out nss
does anyone know exactly which relay or whatever is out. please help me daily driver
One of the many reasons I like dogs more than people.
I certainly hope Karma greets the person who did this to your bike with reckless abandon.
You need a wiring diagram as something is not wired up properly...would the insurance pay for an auto eletrician to check it out?
Good luck and sorry for your experience with the low lifes around.
There is a pretty comprehensive service manual available for this bike online in PDF format. It's just a google search away! I have a copy of it downloaded to my phone just in case.
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf (mods feel free to delete if this link isn't acceptable)
It may be of assistance in this case, but you may be better off picking up the Clymer or Haynes manual, which might be more detailed. I hope this helps.
This is so sad.
I hope you took the time to report the vandalism to the Police.
If you have insurance, you should USE IT.
If not, I'm afraid that you will need professional help.
If the ignition switch assembly was damaged, it may have had a security feature in it that is also damaged.
Discussion Starter #7
well besides my neutral safety light the fuel pump is not coming on. usually i hear it give a few pumps when you click on the ignition, but neither are working correctly
