I bought a 2001 bandit gsf 600 without a fuel.tank i bought one later on off ebay i hooked the tank up and hooked up the vacuume line to the petcock But i still have two lines coming from the carbs that go back to the back of the air box but there is nothing to hook them up to also there is two nipples That look like vacuume ports on the back of the tank i have no clue what to do bought a manualIt tells.you nothing can anyone.help????
The two lines from the carbs are vents for the fuel bowls they rund down to just past the airbox and vent to the outside air. The tank nipples I suspect are from internal standpipes and are to vent fuel fumes to a charcoal cannister which you may or may not have. Alternativly one may be from an overflow...for when the tank is over filled and should simply vent to the rear of the bike.
