1 - 12 of 12 Posts
well my post if pretty self explanitory....i have a 97 gsxr 600 with a full d&d exhaust and i need more power!!!! i have trouble lifting the bike and im getting kinda board. please if any one can help out i would appriciate it.
G
Change out your sprockets. Is it jetted? Get that 520 conversion kit, new sprockets/front and back and chain. It has done wonders on my buddies bike.
hey thanks for your reply smith!
no my bike is not jetted..... what is that conversion kit??? i have a quetion bout jet kits are they bad for your motor like how a turbo is for a car?? about how much do they usally run?
not meaning to butt in to the topic, but a turbo is not bad at all for a car. maybe if you hook it up backwards hehe. but no if it's connected right and all the parts are there a turbo is perfectly fine for a car.
G
Ok, i hope i get this right, and if not, some one will correct me. There are jets in your carbs/FI that "spray" the gas into the motor. Adding a jet kit just modifies the amount that it "sprays" there for giving more fuel/more acceleration/power etc. And the 520 thing, if you up your sprocket size, like in the front, it has to do less revolutions to turn one whole turn. I get them mixed up, but you either go down to wheelie and up for higher top end or the other way around. I havnt done it yet. I have a stage3 jet kit in mine becuase it used to be a track bike and its good for top end but it really dawgs out in lower RPM's. Wish i could help more.
Get some leathers and head to the track. You won't be bored for long.
:lol:
The 520 chain/sprocket conversion kit weighs less, therefore, has less rotating mass than the 530. This allows the motor to use less energy to spin the wheel, creating a faster acceleration rate. For the street, it isn't really necessary, and performance gains will be marginal at best.
Going up one tooth on the front, or a couple on the rear will give you a more noticeable "power" increase. All that is really doing is slightly decreasing the amount of revolutions the front sprocket has to make to spin the rear wheel. Given the same amount of power from the motor, the wheel will spin faster due to the decrease in the revolutions.
Remember if you want to go up more than a couple of teeth in the rear, you might have to buy a longer chain.
More teeth = quicker acceleration
Less teeth = more top end
Jetting is somewhat of a "black art" still. You can get it close if you are good, but the bike will still need to be set up on the dyno for maximum performance. Jetting involves fuel/air mixture. As a rule of thumb, the bigger the jet, the more power the bike will make. HOWEVER, that is not always true. Several bikes I know of ran BETTER and made more HP/torque gains when the jet size was DECREASED. There are so many ways to set up and tune a bike (airbox, filters, porting, cam timing, idle circuit, pilots, mains etc.), and for brevity's sake, I'm not going to go into it here. Find yourself a good dyno tuner (preferably w/a 4-gas sniffer), and shell out the clams to get your bike set up right. You'll be glad you did.
A combination of jetting, re-gearing (changing sprockets) and dyno tuning will most likely give you the best results for the cheapest price. After that, engine mod$ will have to be the next $tep if you are not $atisfied. $$$
:wink:
- Ross
go faster
rejetting is not always necessary, a re-adjustment of the carb needles and the mixture screws will marry the exhaust to the motor. right now their just dating. an ignition advance unit wont hurt either.
If your bike has a full system, and not just a slipon exhaust you will indeed need it rejetted. If you have not done this you are probably making less horsepower than if it was stock.
The very best way is by a pro using a Dyno with the sniffer.
If thats not possible most exhaust companies have charts with suggestions that will at least get you in the area.
G
2002 GSXR-600 - Sprocket Conversion kit
Hey Guys!
I am looking for a little extra pull on my bike...I have heard about the 520 sprocket kit...any comments...Does anyone know a good supplier for purchasing the sprockets??? Also, I am looking to put a full Blue Flame titanium exhaust on my beast....any comments?
This is a picture of me with my bike. It now has Dunlop Z208 slicks, usual K&N Filter, timing retarder, blue chrome shield, basic stuff...Custom paint will be done shortly...
1 - 12 of 12 Posts
