I have a 2007 Yamaha vstar 1100 when I turn key theres nothing. I have a new battery and theres no power on the main 30amp fuse on selonoid.. the only power is on the red and black terminals on selonoid.. any help is appreciated
Not sure I understand what you are saying.
The "main" fuse usually is bolted directly to the same lug on the solenoid as the fat cable coming directly from the battery.
SO.....IF you have power at the battery posts.....and none on either side of the main fuse.....then there is a problem with one of the main battery cables; loose of corroded connection.
The problem can be the negative battery cable, at either end.
