Hi everyone, New to the forum. I just found it while trying to look for a resolution to an issue I am having with my 2009 GZ250. It had been setting for a long time. I got a new battery, Drained the old gas, did an oil and filter change. I got it to run but I could not put any throttle to it with out it dying. It would idle. I pulled the Carb and cleaned it. The choke cable broke on me so for now till the new one gets here I have put in the Pin and spring to keep the Choke off. I can crank it but it has a very slow idle. If I apply just a little gas it cuts off. If I remove the air filter and spray some starter fluid into the throat of the carb it cuts off. If I hammer down on the throttle it sputters a lot then finally starts revving up. As long as I keep 3/4 to full throttle I can get it to run under throttle. If I let go it goes back to a slow idle. Anywhere in between and it dies. Throttle response is also very slow. Thanks in advance for any information or clues you can provide.
Can't do much until the choke is fixed, probably.
You need to be sure that it has a stock air filter on it and no intake leaks between there and the carb.
Then you need to put some Berrymans B12 Chemtool in the gas and run it a few times long enough to get it warmed up.
That is where you need a working choke.
Even when working perfectly, the little buggers run VERY lean on the low end.
The idle passages in the carb are next to impossible to clean by hand.
I had one for a few years and it was a good little bike.
If you search this forum for GZ250" or "GZ 250" you likely will find some of my old threads about it.
Got my Berrymans dip and my choke cable. I will soak the carb parts for a few days and replace the cable and hopefully that will take care of it. I will also check for vacuum leaks.
