I have a 2000 Suzuki Marauder SV800. The bike will not start. The bike has been sitting idle for a few years, although I would start it up every few months just to keep things moving and so the gas would not varnish things up. This past February only the headlight came on, no cranking, etc. I assumed that the battery was weak, I charged it up and a few days later I went to start the bike and I got nothing, the headlight did not even come on. I just bought a new battery since the other battery was a few years old. With the new fully chaged battery installed the engine does not crank, no headlight, no horn, etc. nothing electrical. I have the service manual and I've been checking things out, I have power to the ignition switch, relays and fuses are all good, starter solenoid is good, starter motor is good, I've tested the ignitioon switch, took it apart and tested the resistor, cleaned the contacts of the switch, tested the run and kill switches, everythings is good. all electrical connectors are connected, no bare or damaged wires, etc. Is there a common problem with this bike that I am over looking?
