Many people tend to change their bike's oil more often than their car. Bikes do tend to be a bit harder on the oil. I personally change mine every 2,000-2,500 miles. The manufacturer probably specs something higher. Just as important, if you don't put many miles on the bike, change the oil at least every 6 months or so.
Most will say that if you use good quality oil, 3000 miles is a minimum life. Over at Maximum-Suzuki, some guys have done many oil tests at various lifespans. Rarely, if ever, does an oil start to show significant breakdown before 3-5000 miles.
As for the K&N, be aware that you're going to lean the mixture with the increased airflow. You might need to rejet or adjust the needles to accomodate.
