1 - 18 of 18 Posts
I have a 2007 Kawasaki Ninja 250r and recently I noticed that oil is seeping out of the right side engine cover. SDC10883.JPG What could have caused this and how can I fix it? Please help.:madd:
You'll just have to replace the gasket behind that cover- about $12.00 for the part at the dealer. If you do not want to put it on yourself, figure and hour's labor at a shop.
Not worn, but dried out or maybe the cover has been removed at some point and a bolt was overtightened, crushing the gasket. Did you buy the bike used?
Also, are you sure it is leaking there? Not from around the oil filler cap and dripping down there? If so, you probably need a new o-ring around the filler cap. But if there is no trace of oil between the filler cap and the gaslet, its the gasket.
If you live anywhere near Atlanta I can recommend a shop, or if you are on the North side of Atlanta I can squeeze it in later this week.
I did buy the bike used. The previous owner maintained this bike well though. I'm positive that it is leaking from that point. I have studied the entire engine while the bike was running and that was the only area from which I could see oil coming from. However, I did find another spot with build-up. SDC10882.JPG I've read that this could be from a leak in the air-box. I took a video of the oil leaking from the cover:
. I live in Stone Mountain, but I prefer to do my own repairs to save some $$. Thank you though. :)
She's very pretty!!!!!!! I jsut bought mine back in November and I already want a bigger engine! lol This is my first bike. Unfortunately I'm at work so I can't post a pic of her :(
Although my profile pic is the same color, year, make and model! lol Oh btw since you bought it have you changed the oil? When I bought mine oil was coming out of the overflow and it was because it had an extra quart in it!
Discussion Starter #10
Thank you! This is my first bike as well. I've been browsing for a bigger engine, but I think I'm gonna keep him for a little bit longer. You get attached to your first bike and it's hard to think of letting go.
How much did it cost you? According to everyone I more or less stole mine, If you're interested I'll tell ya the story... LOL
Pop over to the Kawasaki dealer and get clutch cover gasket part number 11009-1872. Not hard to do, just be careful not to damage the oil seals and don't loose the pins.
- Remove the right lower plastic fairing
- Loosen locknut at the clutch lever, and screw in the adjuster to get slack in the cable
- Line up the slots in the clutch lever/locknut and adjuster and then free the cable from the lever
- Remove the lower cable adjuster from the cable holder near the clutch cover
- Free the clutch cable clevis from the clutch lever- now you can get the cable out of the way and get to all the bolts
- Drain all the oil out of the engine- so it is best to wait until you are due for an oil change anyways
- Remove the clutch cover bolts
- Rotate the clutch lever counterclockwise, and it will release from the clutch internals and slide right out of the cover
- Remove the clutch cover, don't loose the locator pins
- Clean the gasket surface well. The old gasket may come off clean, but if not use a 3M pad or brass brush to clean it. Do not use a steel scrapper or razor blade or you risk scratching the soft aluminum surfaces and creating an oil leak.
- Put on the new gasket, and re-assemble in reverse of above. Put in the cover bolts in a star patern to spread out the pressure, hand tight, then go back in star patern and tighten them to 87 inch/pounds with a torque wrench. Do not overtighten or you risk and oil leak. Do NOT just use a socket set and guess- use a torque wrench. If you do not have one, the Autozone or Advance Auto will usually loan you one if you leave a deposit.
- REFILL WITH OIL
- Start engine and check for leaks- you should be fine now.
- If you pull the cover and there is a scratch or chip where the leak is now, the previous owner used something steel to scrape a gasket and boogered it up. Take a photo and post it before you re-assemble and I'll advise you on if it can be fixed at home or if it will need to be welded up and machined back down.
Discussion Starter #14
Great! Thanks! I'm either going to order the part (11009-1872 clutch cover gasket) to be picked up at a store or call around and see who has it. Do you have any recommendations?
Thought you lost us for a bit there Bikerchick :p lol How much did the bike cost you? I got mine for a STEAL!!! 550 :p 1000 miles barely
no reason to let it go. the 250 is a great commuter and very few bikes get the kinda mileage that that'll do. insurance on a second bike is pretty darn cheap as well.
Primo Motorsports on 78 should have one on the shelf. Or I have ordered many times from ronayers.com and cheapcycleparts, although for a cheap part like a $15 gasket it usually is not worth paying the shipping .
1 - 18 of 18 Posts
