Hey y'all, having an overheating issue on my 2007 m50 following a punctured radiator (gravel road).
So far i've replaced the radiator, thermostat, and fan sensor at the bottom of the radiator. I know the fan works as it still turns on if I short the sensor, or after it's been running at idle for a while (last run was about 30 minutes). After about 30 mins at idle, the temp sensor on instrument panel kicks on saying it's hot again. I'm not sure where to go next. my gut is water pump, but i'm hoping someone can give some better guidance for this.
Thanks folks.
After you have rocked bike while running,the thermostat operates at 165 degrees F-195 degrees F, at 195 tstat should be wide open,and you feel discharge preassure by water pump, will tell you if Tstat is open, as said before probably not multi failure of components. Info came out of Cylmers M50 manual 20001-2009
