I have an 04 LC1500 and the low beam headlight & light bar lights are not working. The fuses all tested ok under the rt side cover. The white with gold marks wire behind the head light has no power and that is where the light bar is tapped into.
Any suggestions????? or Ideas where to look.
Has anyone else had this problem?
Discussion Starter #2
Lights fixed
All set.. I overlooked the obvious.
The connector that the dealer installed to splice the light bar into the low beams was NG. I replaced that connection and all works well.
Oops..Sorry
