:smile:
Wheelies 101:
I'm assuming you are wanting to wheelie your dirt bike.
Shouldn't be hard. I've never ridden a ts250 but the basics are the same for all bikes.
The bigger cc bikes (street & dirt) usually have no problems with closing the throttle in the power band and quickly opening it to get a wheelie. Some of the smaller cc bikes need help from the clutch.
The clutch is your best friend for wheelies. By pulling the clutch in, you allow the engine to rev up higher and faster than the chain and sprocket can actually apply to whatever you are driving on. When you let this out, it will cause the torque and accelerational force of the bike to be applied to the smaller front sprocket. This means that the weight of the front of the bike is the zone of least resistance and weight. The front end comes up. Simple.
So how do you do one? Easy. Practice makes perfect. Start small in a closed area.
1.) Ride along at a comfortable pace in 1st gear. For your first wheelies, try to get the bikes in its power band to make this easier. For example: If your bike really starts pulling around 5,000-6,000 rpms, get to around 5,500 rpms.
2.) Next pull the clutch lever in enough to get the clutch to slip. You can pull it in all the way but it isn't necessary.
3.) Give it a bit more throttle. You will need to increase your rpms. For most bikes that means about 2,000-3,000 more rpms for a small wheelie.
4.) Now let the clutch lever out smoothly and quickly. Like when you are trying to pull out into fast moving traffic.
You need to do steps 2-4 pretty fast. You probably won't get it the first few times so keep trying by giving it slightly more throttle after pulling in the clutch.
If you are doing this on a street bike make sure to give your tires time to warm up by driving around for a minute or two. (If you don't, you'll just spin your tire.) The rear brake is what will bring you back down if you get scared. Just tap it and the bike will come back down on two wheels.
There is a lot more that can be done after you get the basics. This is just for popping that front wheel up there. Once you get comfortable bringing the front wheel up high, you can actually ride them.
HTH
