I have seen a couple of 520s go bad. Both of them had less that 10k on them but were both on busa, only one of which was turboed. That one did a massive amount of damage to both bike and rider. The non-turbo busa, all I can vouch for is that it snapped and flew off without doing too much damage, he needed a new rear for his bike and some new underwear but that was about it. I think he may of been down one or two in front but not sure.
Yeah, that's what I figured. 520 is only so good . . .
The gains you get by using one really aren't worth it on the street anyway. On the race track, where the split second acceleration can get you by someone before you dump it into a turn, and then try to pull him/her on the exit, that is where every little detail adds up.
FYI: Decreasing rotating mass on the rear wheel not only causes quicker acceleration, but it ALSO causes the bike to decelerate slower. i.e. when you let off the gas, the bike will not slow down as fast as before. Really noticeable on the track when you are hauling *** into a turn.
It can actually be used to a small advantage in being able to enter the corner a bit quicker. Takes practice. The combination of the quicker corner entrance, and the quicker acceleration leads to faster lap times.
It can also be scary as hell if you have some flatslides not set-up quite right, and have a bit of lag before the motor wants to rev down, and you are flying into that corner with that lighter mass in the back . . .
. . . when I barely made it, I just learned how to go faster :mrgreen:
Damn, I gotta race this season at some point . . .
- Nut
