Having some problems with the aftermarket ignition on the GS1100. Its only firing one coil, I tracked it down to the inductive pickup, both coil pickup are supposed to send a 12v signal back to the module when the magnet passes by, but I am only getting 4 volts on the pickup that is working and 2 volts on the one that is not. Ground and 12v going into the pickups checks good. I sense a bad set of pickups, but would like to keep trying things before I call Dyna Monday. Any electricians out there that have any ideas?
Discussion Starter #2
Oh yeah, this thing ran fine before I put it away for the winter...Get it out of storage and running on 2 cylinders!
