i Have a 1999 Yamaha raodstar 1600
The problem i'm having is it acts like it runs out of gas and shuts down then restarts and runs fine again
some days it won't fail but hear recently it has gotten worse can't trust it
so far I have rebuilt the carb new seals in intake manifold checked pet cock no clogs tank drains to empty no problem fuel is steadily getting to carb
Motorcycle will idle for excessive amount of time and then just die and then restart ?
Does anyone have a electrical idea of were I should start ? Checking im convinced the fuel isn't the problem.!
Moderators note:
I moved your post to it's own thread.
It was not in a good place where you originally put it.
Moderators note:
it sounds electrical. put a multimeter on the computers inlet power and one on coil power. i believe the 1600 is efi. so computer is either loosing power or a signal of some sort. is the check engine light on? if not i think its power related. if it is, it will tell you where to look if you check codes.
Not efi doesn't have any way to read codes.
Mine was dropping rear cylinder first then quitting entirely.
When it cooled down would run fine again. My ecu icm is burning out
Sad part all electricals check ok.
Wish i had the answer.
Check back of ecu for signs of hot spots.
Know what your going thru. Mines doing same thing.
Have cooked 2 ecu's.
If you know how to repair please post to me.
All electricals test good. Have replaced both coils.
Reg/Rec checks fine. All within specs.grounds all good. If you got yours fixed please tell me how. Running out of money.LOL.
