I have a 2004 VL800 and let’s face it, bikes in general are more attractive without the sissy bar (and without the passenger seat). But my wife and I enjoy riding together and the sissy bar is more comfortable for her and we feel safer with it on. But, when I know she isn’t going to ride, I take it off. This is where the problem lies. It takes me a good 20-30 minutes to take off the sissy bar and the passenger seat (and out it back on when she is going to ride). There’s gotta be a faster and/or an easier way to do this without tools or with as little tools as possible. I know that regardless, if I decide to take off the seat, I need to use the Alan wrench. Unless I find a screw/bolt that I can take on and off by hand.
As I am sure you all know, right now, we have to use both the Alan wrench and the pliers in order to remove the four screws for the sissy bar. A quick and dirty solution to eliminate the use of the pliers is to switch out the existing nuts with butterfly nuts. This method will now only require the Alan wrench.
But what if I don’t want to use the Alan wrench. I saw something at Home Depot that might work. It’s like a bolt without threads. The system is similar to this http://www.builderdepot.com/browse.ihtml?pid=114061&step=5&prodstoreid=1718. The difference is that the long pin looks more like a regular bolt. It is long and it has a head. It also has multiple holes. To keep this pin in place you slide in the fastener/hitch pin. I think it might work because they have multiple holes. This way when I remove the sissy bar, the bolt goes further in and if I were to use the same hole as before (since the sissy bar is gone) it would be loose. I just use another hole closer to the fender.
What do you folks think?
