This morning, it was raining (and had been all night) and as I took a 90 degree right hander (turning at an intersection) I passed the end of the centre median and noticed I was lined up to cross over a steel manhole cover.
The pavement was wet and there was a thin sheen of standing water on the cover. I corrected my line to cross it close to the far (outside) edge - as much as I could correct without radically changing my line on the wet asphalt.
The front washed out a little, sliding 4-5 inches off the cover and then immediately gaining grip on the pavement. This process repeated again as the rear touched and slid off the cover onto the pavement.
There was no danger of a highside - I remained balanced on the bike and speed had been kept down to allow for such an eventuality.
Someone watching from a few feet away probably wouldn't have seen anything untoward - however it could definitely be felt on the bike.
As I straightened up I sort of laughed aloud - as soon as I'd seen the cover I knew I would slide on it - kind of felt squidly, in a cautious; prepared-for-it; rode-through-it-smoothly kind of way.
So remember class - steel, painted, polished stone and even paved surfaces can be very slick when wet. A no-brainer, but worth remembering.
