I was wonderin what happen when you change the sprockets on the bike??? Is it for torque??? More Acc.????More Power in general??? Would i change just teh front or just rear or maybe both??? if anybody knows please help??? i have a 88 rm250
Yes I am the Only one, same is me, I am everywhere and no where, do a Google on my name, and you'll see what I mean :mrgreen: ;-)prekarious1 said:Busafied, are you the same one that is over on totalkaos?
True... remember sprockets do nothing for increasing Horse Power it has nothing to do with that. As posted above changing the number of teeth on sprockets will increase top end and decrease bottom end or increase bottom end and decrease top end depending on what you do.ElBandito said:You always have to consider "why do you need more top end ?"
You are geared "best" if tou reach top speed in top gear at the end of the fastest section of the track.
That's competing of course, if you want to go from east to west coast on your RM, consider the " mileage" gearing, biggest front sprocket smallest rear.
As for power/torque, you don't gain "yiksjit", consider sprocketstuff just for what it is, -gearing-, like when in first gear, acceleration is quick, 5th=slower but higher speed.
Bear in mind this very Marauder specificThe front sprocket change is one of the easiest, cheapest and best
mods you can do on a 'Rauder. The sprocket change affects lower rpm
operation very little, but makes a bigger difference at cruise speeds.
A 17 will drop your rpm about 600 - 800 rpm at 70 mph. I've been on
several +400 mile trips with a 16 tooth, and it way more comfortable
than the 15.
