2013 V-Star Deluxe: will not go over 70MPH. Just changed plugs and wires. Anyone know of a rev limiter?
I cant see changing plugs would require resetting one if it did. Does the engine rev cleanly without any misses, are the cables secured correctly and to the correct coils. I can only think there is another problem why did you fit new cables?...I am assuming you are referring to the HT cables here.
There are several different models of V-stars, I think.
Which engine size is your ?
Has it had any intake or exhaust mods done to it ??
Unless you are trying to exceed 70 MPH in 3rd gear, it's doubtful that the rev limiter is the problem.
It wasn't imported from Europe by any chance........?
Does it accelerate strong and smooth until it hits 70 and then just gives up or does it start running bad a bit before 70 ?
