I’m putting some saddlebags on an ’06 C50. It currently has a sissy bar on it and I’m assuming the fender bolts that are there now came with the sissy bar so as to fit that frame and are longer than the originals. When I install the saddlebag mount I’m going to need new, longer bolts. Any idea what size bolts will be needed to fit that assembly?
I say just take the current bolt to Ace hardware or Lowe's if you don't know the size you need. Same diameter probably, just longer. Do a practice run putting it together and guestimate how much longer of a bolt you need.
P.S. the new bags and hardware may include the bolt you need.
